Steve
I wonder what kind of thermostat you've fitted.  I am an advocate of a higher end operating temperature.  The Operators' Manual for the New Super Major (original copies appear on eBay from time to time) says that coolant temp should be in the range 160F - 190F.  I have fitted a stat that keeps her at 190F.  She warms up quickly and sits at this temperature afterwards.  The engine has a lovely note to it and there's no hint of any incomplete combustion.  The link below takes you to a US manufacturer's website, and an explanation of their technology and the theory behind it.  I haven't got one of their stats but I buy into the theory behind it - see extract below.
Food for thought!
Best
Adrian
http://www.dieselsite.com/dieselsite203thermostat.aspx
[url]Question: Why do I want my truck to run warmer?
Answer: You want the engine oil/water temps to be warmer so you get a cleaner, more complete combustion. This can actually bring exhaust gas temperatures DOWN. Diesel ignites from heat of compression. The idea is to compress the air charge to build enough heat to light the fuel, but if it's fighting against a low engine heat, the fuel will ignite, but not as complete as if the cylinders were just a bit warmer. The more complete the combustion, the cooler the exhaust temperatures. Diesel fuel combustion tends to complete best at temps above 200°. An added benefit from using the 203° thermostat is better working cab heaters in the cold months. Another added benefit is better fuel economy. We have seen everywhere from 1-4mpg increases. This depends on climates, driving habits, etc. Even a modest .25 mpg increase will pay for the thermostat in a few miles.
For anyone who doesn't think 8 degrees can make a difference, consider that at 211 degrees water is hot, at 212 degrees, its converted to vapor. At the right critical point for every matter on earth, a degree or a few degrees can make a HUGE DIFFERENCE. [/url]
