Feedback would be nice
Thank you!Tiger wrote:Very nice, i like the instrument panel brilliant. Why do you have 2 batteries
I like the bracket you have made to give the drawbar carrier better support. For me this is the worst part that ford designed on the fordson. It is a pin joint supported only on one side. You have corrected it! Many times I have considered making such a modification as it does not look "right" in engineering terms as standard!Foxen wrote:If anyone is interested, there's some nice shots of our tractors here: http://maskin.b20power.com/#home
I agreeRoadless63 wrote:I like the bracket you have made to give the drawbar carrier better support. For me this is the worst part that ford designed on the fordson. It is a pin joint supported only on one side. You have corrected it! Many times I have considered making such a modification as it does not look "right" in engineering terms as standard!Foxen wrote:If anyone is interested, there's some nice shots of our tractors here: http://maskin.b20power.com/#home
I'm self-taught mostly, have worked as a laser operator so I know what can be done with oneMark wrote:Hey Foxen,
If I were to make a guess, I'd say you are a machinist! Those brass knobs on your dar valve look home made. And the quality cuts of the metal pieces you made for under your seat look good to.
I wish someone with a major would come my way here in Kentucky, the more I read you all's threads the more I want one.
You're doing a good job, just keep it up and keep us posted.
 I wish I had a lathe and a mill myself, would make life easier
