-Pulled top cover and replaced hydraulic filter.
-Drained all hydraulic fluid and replaced.
++once positive hydraulics working, installed a lever operated remote hydraulic kit. Fabricated bracket putting remote lever to top and rear of 3PH lever.
-drained transmission and replaced fluid.
-changed engine oil filter and oil
-drained injector pump and refilled with oil
-replaced fuel filter
-clean and replaced oil in air cleaner.
-complete steering lube.
-Adjusted brakes and emergency brake.
-checked torque on fasters
Tractor has been dependable. This was just my annual service.
Comment: While the lift works normal and is fairly fast and does not drop with implement, the hydralics in remote mode are slow in comparison to my larger tractor. I have a hydraulic self tilting dump trailer, and the Super Dexta takes three times
Ready for work in 2010.
Wayne
