Missing piece construction lifter
Super Major
Post by Super Major »
A few days ago I built a missing piece of the effort controlled, here are some photos:
Image Image
I struggled a bit 'to measure the thread, but using the hard way, I did :lol:
Wow,
Thats really nice work.
Best regardss
Post by Dandy Dave »
Yes, a very nice job. :D Nice to have machine tools. I have a Bridgeport Mill 9 x 42 with a J2 variable speed head. And also 2 Southbend lathes. One is a 16 inch swing X 12 foot bed capable of about 9 foot between centers. The other is a 13 inch swing with a 6 Foot bed, and will do about 42 inches between centers.
I use them often to produce parts made of unobtainium. :wink: Dandy Dave!
Super Major
I unfortunately have only a small lathe and then the thread I had to do :oops: , but apart from that, otherwise I have no problems (drill press, welders, presses, etc. ....) :beer:
You did a fine job Super Major :clap:
Super Major
Thanks, even if the grinding has not been very fine, however you can improve :wink:
The most 'difficult was the thread that could not be measured, (I had to disassemble the lift) so I screwed a piece of aluminum in order to measure the thread diameter and pitch (with deadly force, I refer to this system)
Super Major wrote:Thanks, even if the grinding has not been very fine, however you can improve :wink:
Your method makes an old machinest Kringe. :shock: ... I take it that you have no thread gage's or inside micrometers. Was the thread standard, or metric. At least you got it done. :wink: Dandy Dave!
Super Major
The thread is 3 / 4 "x 25 threads per inch, another problem was that on two lathes, there is this passage, passing from 24 to 26 :o The important thing is that he managed to do so, for the spring (I did not know the size) I used a spring a shock of a scooter :lol:
Most of the time an odd and uncommon thread such as this will require a die. Standard pipe thread is another one. At 27 TPI, it cannot be cut on a standard lathe. Dandy Dave!
