 This would be the point where RPM and rising Torque Meet. Over the curve, and the torque drops. Dandy Dave!
  This would be the point where RPM and rising Torque Meet. Over the curve, and the torque drops. Dandy Dave!Power Curve....
Power Curve....
OK Fellows, At what RPM is our Fordson Major engines most efficient   This would be the point where RPM and rising Torque Meet. Over the curve, and the torque drops. Dandy Dave!
  This would be the point where RPM and rising Torque Meet. Over the curve, and the torque drops. Dandy Dave!Have a Fordsonful day Folks!
Well Brian that is what i was thinking the answer wasBrian wrote:1100 to 1300 RPM Major, 1600 to 1800 on Power and Supers. It works out at PTO speed on most tractors.
Torque will rise to around 1200 rpm then drop.
 .  Didn't ford have to alter the revs on the   super major tractors  as the pto speed was at such low rpms on the older major tractor  it  was gutless when using pulled pto equipment. ?
  .  Didn't ford have to alter the revs on the   super major tractors  as the pto speed was at such low rpms on the older major tractor  it  was gutless when using pulled pto equipment. ?Yes, they brought the speed up to around 1800 for PTO speed.
The problem was, not that the tractor had low power but that the gearbox did not allow a good range of forward speeds at PTO revs.
That was the reason for the 4.4 rear axle.
If you go back to Henretta's time, the PTO speed was around 700 RPM which meant that she had to rev at around 1000 to get 540. I broke a number of connecting rods on my Ransomes mower before I remembered this.
