removing timing case
Hi all, does anyone know if its possible to remove timing case with eng, rad etc still in place - i have removed the crank pulley, and it looks as if cover will clear etc!Anyone done this ? any tips etc? Its a `59 power major by the way. Thanks in advance, rich.
1984 5610 FWD ,1981 ford 4610 ,1962 dexta,1959 power major, 1952 major, 1956 major, 1961 super major.
						Hi Rich,
You mean the case, that is bolted on the engine-plate with several bolts? When you have the crank pulley off, I don't see any
problems. Perhaps some oil?
Please be carefull to remember which bolts belongs in which wholes. Some of the bolts have different screw thread
Good luck!
 Good luck!
Best regards,
Pascal
						Pascal
				YorkshireDextaMan
