A few quick questions.
I will be 'extracting' the block from my Dexta on Saturday and following a strip down it will have new liners fittted and bored to size.
Question is, is it worth while extracting the old liners myself so I can get a good view of the block internals and if so, what is the best method for this (extract using threaded bar plus suitable drifts etc or hydraulic press).
Are they stubborn buggers to shift?
						Dexta liners
The word you are looking for is "impossible"!
I have been told that a bead of weld in the liner will allow them to be drawn out easily but I am always worried I would burn through the thin liner and weld it to the block.
If you are having new liners fitted and bored, let your machine shop remove the old ones.
				Aussie Frank
Hi Russel,
Brian is right let the machine shop do the work and get them to hot tank it to get the rust out of the block while they have it if you can. Please do make sure that no white metal bearing such as cam shaft bearings will be damaged by the cleaning process though.
Getting the liners out would have been a dissapointment for you as all you would have seen is another metal cylinder. The dexta has dry liners so you do not get to see the water jacket when they are out.
Regards, Frank.
Regards, Frank.
