how do you know when you should just pay up and buy a whole new water pump?
Its making some noise(more than the motor)
it leaks a little
but it still pumps like a...
thing is $30 to $120 i know a new pump would be shiny and easy but what do i look for in the old one to know that it is beyond repair?
is it that hard to pull down? the impeller seems fine can i just fit a standard bearing seal?
									water pump rebuild or new
				greendoglive
Dexta 1958?
957E 7905
C25B
						957E 7905
C25B
I recently useda repair kit from Agriline.
It took about an hour to do using hand tools and a puller.
I had to heat the casting with a blowtorch to extract the old bearing assembly, the new one went in no problems and so far all OK!
