I am restoring my super dexta 1963 diesel model and i have some troubles with the hydraulic system. When i lift up the arms without any load..... the arms plays up and down for 4 cm at any possition continuously.
Why that happens ?
						Hydraulic problem
is this your problem?
http://www.dailymotion.com/video/xd2ug7 ... _lifestyle
Lift the arms to the top, stop the engine and pull out the auxillary service knob.
What happens? Does the lift drop or does it stay up?
If it drops, problem is piston seal, ram cylinder safety valve, ram cylinder "O" rings.
If it continues to drop, the problem is control valve, unload valve, check valve.
Bent linkage/linkage adjustment is covered in an article on the Wiki. (fordsontractorpages and dotty are the codes you need to access).
Do you have a long/heavy implement on the arms?
