The large pin supporting my hitch assembly on the Top Link Rocker Bracket is seized solid, ive tried beating it stupid with a club hammer and dosing it with WD40 but it just wont move, any ideas folks?? Ive heard heating it can make it worse??
Donegal Dexta
						Seized Pin - Top Link Rocker Bracket
				Donegal Dexta
 - Contact:
The welding trick is a good one. We have a machine at work which uses large taper rollers. Unfortunitly the outer race is pressed into a blind shoulder so there's no way to knock them out from the back. We run a bead of weld around the inside and when they cool they just drop out.
A weld on the inside diameter of most things will shrink them.
