Howdy all,
I'm new to the group.
I have a '59 Dexta, diesel; which has a bad starter. Coil/field stud broke off and disconnected, plus the drive gear needs replace. I searched the web for replacement/rebuilds, and ordered the "newer" lucas system from mid atlantic parts. This new starter has about 1/2 " less throw (engagement) length than the original lucas.
Any suggestions on where I might get a resonable replacement starter??
Jim
Starter Help
Jim Cultra
jim, re: starter
If you live in the USA try Burgh Implement somewhere in PA. they have a website. I just bought a throw-out bearing from them so I know they have a diesel Dexta in the back lot.
Fordson dexta owner for 25 years; do all the work myself.
where abouts are you located might be able to help. dexta starters are quite expensive not not all that comman, the back half of a major starter is identical. the front aluminium casting is a mirror of the dexta one. and both starters rotate the same way. you can swap parts about between the two. worked for me.
regards,
regards,
Dexta Starter Motor
Hi Jim
There is a Dexta starter currently on eBay (DEXTA) 5 days left.
JOHN
JOHN
