 TSG.
 TSG.Major distributor caps
				The Swanndri Guy
From a post from "Yesterdays Tractors" , that distributor caps for Fordson Major's E1As 1951-64 with spark ignition are available at  www.gsparkplug.com  Listed as Lucas DDB163, 415298, 408369. Can any one verify that this is correct? I thought I  should post this on FTP due to the problems other people in the past in trying to obtain distibutor caps for their TVO/petrol Major's.  TSG.
 TSG.
									 TSG.
 TSG.Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
						Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
It would be great if they were available. We did think they were the same as the Mk1 Land Rover but they are not.
There are also two distributors that Ford used. The one on Henrietta is different from the one fitted to Steven B's Major. So check the Lucas number on the inside of the cap before ordering.
				Tractorbob3
On my 52 E1ADKN, the distributor is stamped DM4 40275A.  I got help from a guy called the Distributor Doctor here in the UK  (www.distributordoctor.com) and he supplied a complete set-up for me.  The Lucas part numbers are:
Rotor arm - 408355
Points - 419398
Condenser - CI 423871
Distributor cap - 418659
Hope this helps ...
									Rotor arm - 408355
Points - 419398
Hope this helps ...
Regards - Bob
1961 Super Major
						1961 Super Major
				The Swanndri Guy
Distributor caps
CNH lists 81751855, 1/1/52 to 31/3/57 (Lucas 418859) and ETOA 12116 ,1/3/57 to 31/12/64.
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
						Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
				Tractorbob3
Humblest apologies all - Brian, you are right (as usual) - closer inspection has revealed that the correct number for the cap is 418859.
Sorry if I've caused any confusion - should have gone to SpecSavers (which I guess won't mean a darned thing to our many overseas cousins!).
Regards - Bob
1961 Super Major
						1961 Super Major
