Do I lose Proof meter and tach?
Winchester
Post by Winchester »
I live right by a heavy trafficated road, as a safety measure I have put some side lights/indicator lights, extra set of front wide beam lights, one rear wide beam light, a emergency ligt on the roof and the stock front lights. This is to much for the chargins system, and I have battery drain, even with the engine running.
If I change to a more modern alternator, would it then lose the proof meter and tach?
:beer:
Tom T. Winchester
Little did I know that all those days passing was life itself!
Re: Do I lose Proof meter and tach?
Post by Bensdexta »
Winchester wrote:If I change to a more modern alternator, would it then lose the proof meter and tach? :beer:
I don't see why you should, as the proof/tacho are entirely mechanical, with no electrical input (apart from the dash light) :wink:
Winchester
OK, must have read something to fast then :) Thank you :)
Tom T. Winchester
Tubal Cain
Site Expert Team
Site Expert Team
Post by Tubal Cain »
If you convert to an alternator,and your existing dynamo is positive earth you will have to change over to a negative earth system.
Gerald
Post by Jerry Coles »
If you are considering converting to an Alternator then take a look at the top of the Dexta section, third item down 'Looking for informnation...'. There is my contribution on wiring up a Dexta with Alternator, turn lights etc. This may help you.
Camerton
Bath
UK
russelm
Post by russelm »
Tacho is driven off the fuel pump so the drive wont be lost
