Hi , would anyone know of the number of links and the size of links used in the orignal chains for lift arms,
as mine are not orignal i would like new ones as close as possible to orignal. Thanking you Gerry
chain for lift arms
Re: chain for lift arms
Gerry,
7 links> 5/16" X 1 3/4" (Outside length) between 2 clevis 1 3/4" long with 11/32" pins giving a total length between pin centres of ~11".
Measured on a '61 Petrol Dexta and '62 Super Dexta looks to be the same.
Cheers,
Les
Cheers,
Les
Thanks Lesfen for taking the time to mesure up and that, this is a great help the chains i had where 2inch links+clevis links always thought they where wrong
it good to have correct sizes before i get new ones, regards Gerry
They are readily available from suppliersGERRY wrote:it good to have correct sizes before i get new ones, regards Gerry
