Belt pulley for a Major
I recently picked up a belt pulley assembly for the side of my Major but the pulley itself was missing. The shaft seems to be a 1-3/8" six spline, but it does not interchange with the splines on the PTO. Is there another make of pulley that will interchange with the Fordson? As near as I can determine, the pulley should have about an 8 inch diameter. Thanks.
Never give up!
- Contact:
Re: Belt pulley for a Major
Kim,
That shaft should have a spline that will fit in a pulley wheel and will not correspond with a pto spline.
