Therefor I need to lokate two diesel line end fittings. Anyone know where I can find them and what thread size and dimentions they are?
Diesel line fitting
Winchester
Diesel line fitting
Changed out the diesel tap for an original Fuel Tap Primer Pump. At some point they have removed the original diesel line end fittings to make it fit with a aftermarked fuel tap.
Tom T. Winchester
Little did I know that all those days passing was life itself!
- Contact:
Re: Diesel line fitting
Tubal Cain
- Site Expert Team
The main fuel lines are 1/4" copper pipe fitted with olives and 1/2" UNF male nuts. The spill line is 3/16" copper with 3/8" UNF union and male nuts.
CAV fittings used to be imperial but they have now converted to metric so you may have a problem obtaining the correct fittings.
Gerald
Gerald
