I am still struggling to get my Automatic Pickup Hitch on my Dexta to fit correctly. The hitch itsef is not vertical so does not fit to the plate correctly so any implement fitted is not secure. I think I need to change the anchor bracket as the one I have fitted does not look like the one in the spares manual. The part number of the one I want is E77 QF 9 and is described as:- Bracket (Auto Hitch Anchor).
Can anyone help please?
Bracket
woodseaves
- Contact:
Re: Bracket
do you have the plate that sits above the "hook" when it is in the locked position?
Regards,
Regards,
woodseaves
- Contact:
Re: Bracket
Yes, after a lot of searching.
woodseaves
- Contact:
Re: Bracket
Just to put this one to bed. It is now clear that all the pickup hitches I have bought on E Bay advertised as Dexta are a mixture of different models. The actual hook and attached frame is wrong on them all. I don't think it matters with the hook but the attached frames on my bits are 3" to big so they don't fit vertical. Lesson learned.
