rear axel oil colour
hi all, changed the oil inthe back axel last summer, been using back end loader for the last few days, when disconnecting the hydraulic pipe from the tractor i noticed the oil is already turned a milky colour is this normal , dont think there is any water getting in their. thanks in advance for any help.
Jos Cuypers
Re: rear axel oil colour
Milky colour = water.
This water can come from the condensation in the rear axle or from the loader(previous oil having a lot of mixed water and loader not purged when changing the axle-oil) .
When the loader has a single-acting cylinder, the rear axle oil-content drops when operating the loader, as there is a transfer of rear-axle oil into the loader so air (with humidity) will enter the rear axle due to the underpressure. ... So after some operating-hours the rear axle has "breathed" several times...
Rgds
Jos
Jos
thanks jos your reply makes sence, i never thought of purging the loader ram before use, also we had an unusally cold winter here which would have added to the condensation problem. regards ollie.
Hi i cant add to the answer jos has given , but was wondering if you could post a picture
of your back end loader as iam trying to get a make for mine without much luck,
there is no name plate ect on it . Gerry
dont think i can help you " gerry " mine has no name plate either. i think it might be home made or made by a small engineering company. Its not one of the brand names like tanco etc. Will try and post a picture tomorrow. regards ollie.
