down , she will lift the tipper as usual and drop it no problems , when iput it in position control ,, she
will lift ok but will not stop untill the tipper is fully raised ie ican not control it , and it will not drop untill i push the draft leaver downwards, it wont drop in position , this is only with the trailer when ihave the link box
or other implement on position works fine.
