Leak off rail bolt needed
ollie
Post by ollie »
the bolt that attachs the leak off rail to the bottom right hand side of the fuel pump on my 1957 fordson major diesel snapped when i was removing it and i canoot find a replacment any where i was wondering if any one knew where i could get one or had one i could have???
many thanks
ollie
Re: Leak off rail bolt needed
Ollie,
It's easy to make one yourself.
Buy the right size at the CNH dealer. Drill a hole in the length, but stop before you get to the head of the bolt. Than drill a hole from the side a few mm behind the head until you come out at the first hole. To get it work even better you could file the threat away just behind the head. Put two new copper washers on each side of the pipe part and it will work.
halloween
Post by halloween »
Hi, the bolt in my pump just has a slot cut along the thread to near the head. That may be easier to do??
I think thats the correct way to do it and much stronger.
ollie
Post by ollie »
thanks for the advice much appreciated :)
