Hi there,
I've just fitted the rear crankshaft rope seal and crankshaft into my Super Dexta engine. The crank seems a little stiff to turn and i am sure this is down to the rope seal, however I'm pretty sure I have fitted it correctly.
The crankshaft can be turned by had but takes a fair bit of force, is this normal? Roughly what amount of force should be needed to turn the crank?
Crankshaft Rope Seal
YorkshireDextaMan
Re: Crankshaft Rope Seal
Yes, if you can turn it by hand it would be quite ok, thats provided the crank turned freely by hand before you fitted the seal. Allways best aswell to give the ropes a little soak in oil . Jim.
Ah right thanks, yeah it did. I soaked the ropes in oil for a few hours before hand and fitted them okay, i just wasn't sure how free the crank should be, i guess I've fitted them okay though. Thanks again
Hi John, I also usually do like you did, but I also after some houres do take it appart again and soak it again befor assembling. (aspecially if I am worry of "to heavy fork" for turning...)
But it is also a tip for they who are taking out the crank and all bearing,s...not use oil on "backside of bearings". Do dry off all backsides (there nothing moves) use oil only on movable surfaces when asembling. This is aspecially for Main bearings and rod bearings.
blue32
blue32
As has been said, always oil the seal and bearing surfaces as you assemble.
This idea works too especially on engines that are not going to be running very soon after assembly, I now always use a smear of Moly. grease on seals and bearing surfaces. Oil can dry out if the engine is not run, leaving the bearings dry.
Thanks for the advice guys, I've given the seal and bearings a good dose of oil and assembled the crank and pistons and everything seems to be turning okay!
