to find it mybe someone can help me out here , got me a back actor, the guy had it working
well off adexta , got it home hooked it up an cant get it to work , now it lifts the actor no
bother, but when i pullout the services valve to lift or move bucket nothing,
plenty oil inback end ,
should this be running connestantly when in use or just when one moves the valves ,
here this as i understand it .
feet down
services valve pulled out
returned pipe in back end
operate digger what am i mising here
could the problem be in the pump even if it lifts the back end and the tipper always works the trailer
