New fuel filter housing
The new one has no bleed screws,I'm assuming you bleed it by loosening up the bolt on top?
Thanks,Lee
Re: New fuel filter housing
Just following up on some old questions.
I think it's best to get the correct head with bleed screws.
Agree 100%, if you don't have the bleed screws loosen the pipe off, as it avoids messing up the filter seal.
Wed Aug 11, 2021 8:44 pm
Thanks Sandy! Simple solution I hadn't thought of!
