Hello Brian
Not sure if my PM got through to you. Please will you contact Gerald Taylor re his PASSWORD.
Kind regards
Mervyn
Help required
Mervyn Spencer
Re: Help required
Not about much at the moment Mervyn but no PM came through. Gerald Taylor is not registered as that, as far as I can see, what is his site name?
Mervyn Spencer
Re: Help required
Tubal Cain(spelling??)
Mervyn Spencer
Re: Help required
Brian were you able to help Tubal Cain to log on to the forum?
Re: Help required
Yes, He should be back and running after a bit of messing around. I had the same problem for a while too.
Mervyn Spencer
Re: Help required
Thanks for helping Gerald Brian, I did not want Gerald to feel I did not get in touch with you to assist him.
Tubal Cain
- Site Expert Team
Re: Help required
Mervyn,
You can relax as you can see I am back on line again. Although I was running round in cirles for quite some time.
The reason that I contacted you was because you were the only member of the Forum whose e-mail address was in my address book.
Many thanks for your assistance.
Gerald
Gerald
Mervyn Spencer
Re: Help required
You are welcome Gerald, it was a pleasure to assist you
