Flushing out Hydraulic systems
MartyBoyce
Post by MartyBoyce »
G'dau all ,
I need to clean out the hydraulic system on the bucket arms , it has had whatever sort of oil was available in it over the past couple of years and while I recondition the ram seals it is probably best to clean out the entire system . Question is what is the best thing to flush through the system without causing damage to hoses etc ?
cheers,
Marty
Some say that she is ugy , just a relic from the past
new tractors do it better and new tractors do it fast
but to me she is a beauty , every curve and classic line
My old Blue Fordson Major , hell to me she'll do just fine
Re: Flushing out Hydraulic systems
Post by Bensdexta »
Brian says a 10:1 kerosene/eng oil mix can be used to flush out the back axle / hydraulics: http://www.fordsontractorpages.nl/phpbb ... 40&p=14786
Might be best to check with him first though.
MartyBoyce
As per the answer on my other post , the hydraulics are run from a front mounted tank spearate fromt he rear drive , but a kero oil mixture sounds ok , my major concern was not to use something that would perish or damage the hoses etc
Thanks,
Marty
