Has anyone had to replace the oilfeed pipe from the block to the cylinder head?
Mine is corroded and starting to leak. I have not seen them advertised through the normal Fordson parts suppliers, are the fittings the same as that used for automotive brake pipes?
Oil feed to rockers
Chris Ivin
Oil feed to rockers
Chris
Brailes, UK
"Dexta's rule the World!"
Brailes, UK
Tubal Cain
- Site Expert Team
Re: Oil feed to rockers
Hi Chris,
I think that the pipe is 3/16" od and the fittings are the compression type with an olive and not a flare as used in brake lines.
Gerald
Gerald
Chris Ivin
Thanks Gerald,
I'll get hold of some 3/16 OD copper pipe and olives, hopefully the fittings can be reused.
Chris
Brailes, UK
Brailes, UK
Hi there, I had the same problem with mine. As said above, use some 3/16 brake pipe and brass olives, i also re-used the original nuts, and its been fine since!
