High clear dexta
High clear dexta
Do you think there would be alot of work to make a high clear dexta? and would it be possible?
Owner of a 1961 fordson dexta restyled model
- Contact:
Re: High clear dexta
What a nice idea. It must be possible. Depents on if you have the right tools, machines and parts
There is no reason why it cant be done, there was one on eBay earlier this month (item number:181069628427), by the looks of things it just has larger wheels on the rear and a deeper drop axle on the front, not sure if there is anything done to the gearing to compensate for the change in wheel diameter
Sounds like a great project!
Will
Will
1962 Super major
1960 4wd dexta (home built)
1963 Super dexta
1963 Super dexta
