Hi folks.
Currently searching for a bearing to my Supermajor, but it seems impossible to find.
Its the needle bearing that is fitted into the back end of the main shaft coming out og the gearbox and into the clutch. (Double clutch)
Any ideas where to find it ?
Max Madsen
Denmark
Hard to find bearing
Re: Hard to find bearing
One would suspect that if you took the sample into a bearing supplier that they would be able to supply it or offer to obtain it for you -- especially if you were also able to give the sizes of the shaft and housing.
- Contact:
Could you give the measurements?
