I'm in the process of changing my engine oil (see my post on a different aspect of this!), and want to change the oil in my injector pump. Something odd is afoot with the filler screw, it seems. In the picture here:
https://docs.google.com/file/d/0B7yIOIq ... sp=sharing
you can see that there is a square nut where the filler should be. In my case, this seems to have a threaded hole drilled into the centre of it. Initially, I thought that someone had lost the filler nut (groan!), but it's actually a blind ending hole. Moreover, there are traces of paint on the square nut, which seems to indicate that nothing has ever been screwed into the hole. True to form for this tractor, I don't seem to be able to get the nut undone!
Is this arrangement familiar to anyone?
Cheers,
Chris
Injector pump oil filler
chrism0dwk
Les bryant
Re: Injector pump oil filler
Chris Give me a phone call and I will take you through everything you want to know as I have a workshop manuel for super dexta and I also first started driving dexta in 1962.
Cheers Les.
Cheers Les.
you need to unscrew that nut as that,s the filler hole
