Hydraulic assembly
Hydraulic assembly
How much do you think the entire hydraulic assembly should be worth from a salvage yard?
Re: Hydraulic assembly
Hydraulic tops (ie pretty much the hydraulic system, less pump) typically go for £75-£150 on ebay.
Les bryant
Hi I picked 1 up at wrecker's yard complete with arms for $80 nz dollars
Cheers Les.
Cheers Les.
