Hello
Question, should the inside of a Perkins cast sump be painted ? if so what paint should be used please
Thanks in advance
Mike H
sump painting ?
Re: sump painting ?
i stand to be corrected but if i were you i wouldnt. The last thing you want is the paint coming off and blocking your pump, proper paint or not
Mike H
Re: sump painting ?
Ok that makes sense, thanks for the input
Mike H
Mike H
