I am about to wire a combined ignition and light switch  on my 1960 Dexta.  It has an alternator fitted and is negative earth.  All the wiring diagrams show seperate switches with a dynamo and regulator box.  I am also interesed in the wiring of the oil pressure light and the charging light.  Any simple help  would be appreciated.
						Combined Key and Light Switch
				woodseaves
 - Contact:
Re: Combined Key and Light Switch
click on Steffans workshop manual link, chapter 9 electrical system, you will find easy to follow diagram in that section
				woodseaves
 - Contact:
I am aware of that wiring diagram,  I was looking for a wiring diagram that  does not include the regulator box and has got an alternator not a dynamo, also with a negative earth.
I have a diag with alternator & -ve earth, but separate 'ignition' and light switches. I used a standard Dexta wiring loom, with simple mod to the diag in the manual.woodseaves wrote:I am aware of that wiring diagram, I was looking for a wiring diagram that does not include the regulator box and has got an alternator not a dynamo, also with a negative earth.
Fairly straightforward to omit the separate ignition switch and wire straight to the combined light switch. I also have a circuit breaker, but that's easy to omit. PM me if it's of interest.
				woodseaves
 - Contact:
Thanks Ben, sorry for the delay I've been on Holiday.  I managed to sort it all out with a little thought.  Thanks again.
