the end of my project comes in sight, so here is a little status update:
http://predecke.auge.de/html/traktor4.html
The whole story starts here: http://predecke.auge.de/html/traktor.html
Friday I have a date at the german TÜV to get the technical approval for road use.
Linkage is still missing. Nearly all parts a bend or welded, I'll mount them after the technical checks.
Peter
The french Super Major in Germany
1963 Super Major
Re: The french Super Major in Germany
Hervorragende Arbeit
Translation: Great Job
my Fordson is lightyears away from a state like yours..........
Regards Matthias
With County, you can
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
1959 Power Major
1963 Super Major
1966 County 654
- Contact:
Peter,
You can be proud on yourself. You've made ity a beauty.
and in Germany I suppose
Mervyn Spencer
Congratulations your blue girl looks very impressive, well done.
Nice!
Dandy Dave!
back from TÜV: I got the technical approval.
Next is "Zulassungsstelle", the authority in Germany to give you a number plate. I got no papers with her, let's hope, she's not stolen in former times. They check it in whole Europe, but it works online, so you know instantly.
Peter
Peter
1963 Super Major
last update: Got the numberplate, now she's allowed to be on the road.
Next job is to stop her leak oil around.
Peter
Peter
1963 Super Major
AdrianNPMajor
Frohbotschaft, Peter. Jetzt kannst du eine Spritztour machen!
Re your leaks, where are they? All fixable, of course - some more easily than others!
Best
Adrian
Best
Adrian
After our holidays and in a not so rainy day i'll take a tour.
Leaks are on front crankshaft, somewhere near the clutch, brake pedal axis and the rear axle trumpets(?) . Injection pump also leaks oil a bit. Work for the winter ...
Peter
Peter
1963 Super Major
AdrianNPMajor
Hi Peter
The front and rear crankshaft seals involve a bit of work. I've got the same problem after not doing the job properly when I rebuilt my engine.
The brake/clutch pedals cross-shaft seals are not so troublesome. The rear axle trumpet housing seals are also doable relatively easily. Lots of info and photos available on this forum for all these jobs.
Best
Adrian
Best
Adrian
