Fordson Industrial Engine serial Numbers
Jimcdbts
Post by Jimcdbts »
The Fordson tractor engine was available as an industrial engine from the outset of tractor production ,however in 1957 with the introduction of the mk2 engine and also the introduction of the Thames Trader a new range of Industrial engines was introduced the 589E ,590E ,591E and 592E 4 and 6 cylinder petrol and diesel engines. These were produced on a dedicated engine line and were introduced in 1957 and made until July 1967for 6 cyl and April 1970 for 4 cyl . They all have serial no beginning with S and some can be found fitted to Fordson majors as replacements. Thames trader engines can also sometimes be found in the tractors and these also have separate serial nos with a different prefix 530E for the 4 cylinder diesel. I have copied the serial nos into tables a will post here, it is an incomplete listing as i am missing the data for early and late Thames trader engines and some early nos for the industrials In March 1965 the engine line at Dagenham started to produce the new 2700 range derived from the earlier range. These were produced as both industrial and truck engines for the new D series. The two engine ranges going down the line until July 1967 for 6 cyl and April 1970 for 4 cyl ,when the old range was discontinued. In March 1964 the engine castings for all tractor ,truck and industrial engines ceased to be sourced from the Dagenham foundry and were instead supplied by Sterling Metals Ltd of Nuneaton. All engine castings for the old range of engines up until April 1970 came from this source.The serial numbers should be usefull to those trying to identify and date tractors with these engines fitted instead of the proper tractor engine. Prior to The introduction of the 598-592 range engine the industrial engines had other designations ie 954E 4 cyl Diesel, 955E 4 cyl petrol ,956E Vap oil, 562E 4 cyl Diesel, and 563E 4 cyl petrol all versions of the tractor engine.I don`t have any serial no details of these engines. After April 1970 the old range of 4 cyl 592E engine was manufactured for Ford by Ebro in Spain and was supplied with a proper S industrial ford serial no until 1974 after which it became a purely Ebro engine with no Ford logo or serial no.
Ford Industrial Engine Serial Numbers (FORDSON TYPE)
589E 6 cyl petrol, 590E 6 cyl Diesel, 591E 4 cyl Petrol, 592E 4 cyl Diesel,see the later list for serial nos after 1967 as 592E still available with Industrial S serial number up until 1974.
Jan-57 S??????? Sep-60 S202905 May-64 S382700
Feb-57 S??????? Oct-60 S206901 Jun-64 S390839
Mar-57 S??????? Nov-60 S210942 Jul-64 S394937
Apr-57 S??????? Dec-60 S214742 Aug-64 S394956
May-57 S??????? Jan-61 S217975 Sep-64 S400673
Jun-57 S??????? Feb-61 S221604 Oct-64 S406675
Jul-57 S??????? Mar-61 S225057 Nov-64 S418756
Aug-57 S??????? Apr-61 S227978 Dec-64 S422678
Sep-57 S??????? May-61 S231414 Jan-65 S440281
Oct-57 S??????? Jun-61 S236082 Feb-65 S445910
Nov-57 S??????? Jul-61 S237874 Mar-65 S451298
Dec-57 S??????? Aug-61 S238903 Apr-65 S457000
Jan-58 S??????? Sep-61 S242359 May-65 S463428
Feb-58 S??????? Oct-61 S244400 Jun-65 S469622
Mar-58 S??????? Nov-61 S249731 Jul-65 S482814
Apr-58 S??????? Dec-61 S255104 Aug-65 S484589
May-58 S??????? Jan-62 S257192 Sep-65 S487681
Jun-58 S??????? Feb-62 S259489 Oct-65 S498509
Jul-58 S??????? Mar-62 S262626 Nov-65 S502046
Aug-58 S??????? Apr-62 S268839 Dec-65 S510728
Sep-58 S??????? May-62 S272344 Jan-66 S513700
Oct-58 S??????? Jun-62 S275066 Feb-66 S523258
Nov-58 S??????? Jul-62 S279924 Mar-66 S531279
Dec-58 S??????? Aug-62 S282285 Apr-66 S535394
Jan-59 S??????? Sep-62 S289685 May-66 S539792
Feb-59 S??????? Oct-62 S293014 Jun-66 S542772
Mar-59 S152148 Nov-62 S295456 Jul-66 S547427
Apr-59 S154346 Dec-62 S299492 Aug-66 S553502
May-59 S156723 Jan-63 S302340 Sep-66 S559860
Jun-59 S158770 Feb-63 S306878 Oct-66 S570998
Jul-59 S160725 Mar-63 S310092 Nov-66 S577774
Aug-59 S162216 Apr-63 S313698 Dec-66 S584206
Sep-59 S163319 May-63 S319286 Jan-67 S592917
Oct-59 S165585 Jun-63 S327953 Feb-67 S601371
Nov-59 S169826 Jul-63 S334757 Mar-67 S605856
Dec-59 S173638 Aug-63 S336412 Apr-67 S607484
Jan-60 S178862 Sep-63 S341829 May-67 S612949
Feb-60 S180946 Oct-63 S343696 Jun-67 S616139
Mar-60 S184210 Nov-63 S355712
Apr-60 S186928 Dec-63 S359567
May-60 S189906 Jan-64 S362864
Jun-60 S194532 Feb-64 S365837
Jul-60 S198584 Mar-64 S369385
FORD THAMES TRADER ENGINE SERIAL NUMBERS.
528E 4 CYL PETROL, 530E 4 CYL DIESEL, 508E 6 CYL DIESEL, 510E 6 CYL DIESEL
DATE 15TH OF MONTH 4 CYL ENGINES 6 CYL ENGINES DATE 15TH OF MONTH DATE 4 CYL ENGINES 6 CYL ENGINES
Jan-57 ????? ????? Apr-60 17522 46167
Feb-57 ????? ????? May-60 17963 48135
Mar-57 ????? ????? Jun-60 18646 49708
Apr-57 ????? ????? Jul-60 19178 51667
May-57 ????? ????? Aug-60 19291 52550
Jun-57 ????? ????? Sep-60 19291 54650
Jul-57 ????? ????? Oct-60 20569 56895
Aug-57 ????? ????? Nov-60 21184 59101
Sep-57 ????? ????? Dec-60 21987 61594
Oct-57 ????? ????? Jan-61 22652 63888
Nov-57 ????? ????? Feb-61 23092 65786
Dec-57 ????? ????? Mar-61 23466 67386
Jan-58 ????? ????? Apr-61 24651 68789
Feb-58 ????? ????? May-61 25024 71159
Mar-58 ????? ????? Jun-61 25398 73484
Apr-58 ????? ????? Jul-61 25630 75130
May-58 ????? ????? Aug-61 26050 75130
Jun-58 ????? ????? Sep-61 26471 77534
Jul-58 ????? ????? Oct-61 27089 78273
Aug-58 ????? ????? Nov-61 ????? ?????
Sep-58 ????? ????? Dec-61 ????? ?????
Oct-58 8988 17300 Jan-62 ????? ?????
Nov-58 9302 18472 Feb-62 ????? ?????
Dec-58 9632 19358 Mar-62 ????? ?????
Jan-59 9713 19986 Apr-62 ????? ?????
Feb-59 10330 22238 May-62 ????? ?????
Mar-59 10758 23267 Jun-62 ????? ?????
Apr-59 11164 24529 Jul-62 ????? ?????
May-59 11717 26121 Aug-62 ????? ?????
Jun-59 12311 27818 Sep-62 ????? ?????
Jul-59 12775 29813 Oct-62 ????? ?????
Aug-59 ????? ????? Nov-62 ????? ?????
Sep-59 13664 32859 Dec-62 ????? ?????
Oct-59 14249 34730
Nov-59 14774 36139
Dec-59 15210 38002
Jan-60 15768 39995
Feb-60 16975 42036
Mar-60 17250 43892
Ford Industrial Engine Serial Numbers(2700 RANGE)
2701E,2703E,2704E,2706E,2708E,2709E FEB1965-NOV1969 2704ET JULY1968-
2701C,2703C,2704C NOV 1969-OCT1970 2711E,2712E,2713E,2714,2715E OCT 1970-
DATE 4 Cylinder 6 Cylinder DATE 4 Cylinder 6 Cylinder
Mar-65 S451234 S451160 Jul-68 S663466 S663365
Apr-65 S456988 S457000 Aug-68 S665638 S665614
May-65 S463500 S463428 Sep-68 S669070 S669122
Jun-65 S469602 S469622 Oct-68 S672680 S672717
Jul-65 S482855 S482814 Nov-68 S676010 S675927
Aug-65 S484719 S484589 Dec-68 S679912 S679561
Sep-65 S487767 S487681 Jan-69 S683382 S683401
Oct-65 S498781 S498509 Feb-69 S687876 S687887
Nov-65 S502039 S502046 Mar-69 S689085 S689257
Dec-65 S510720 S510728 Apr-69 S692583 S692903
Jan-66 S513699 S513700 May-69 S698971 S698936
Feb-66 S523275 S523258 Jun-69 S704666 S704720
Mar-66 S531330 S531279 Jul-69 S709780 S709738
Apr-66 S535576 S535394 Aug-69 S711205 S711310
May-66 S539792 S539737 Sep-69 S718809 S718889
Jun-66 S542772 S542967 Oct-69 S724259 S724330
Jul-66 S547427 S547407 Nov-69 S730101 S730123
Aug-66 S553502 S553501 Dec-69 S734686 S734679
Sep-66 S559896 S559860 Jan-70 S739057 S739033
Oct-66 S570998 S571109 Feb-70 S743716 S743743
Nov-66 S577777 S577774 Mar-70 S747734 S747873
Dec-66 S584206 S584197 Apr-70 S752487 S752471
Jan-67 S592932 S592917 May-70 S757830 S757874
Feb-67 S597885 S597967 Jun-70 S763441 S763454
Mar-67 S601371 S601347 Jul-70 S767717 S767775
Apr-67 S606363 S605856 Aug-70 S769792 S769807
May-67 S607804 S607484 Sep-70 S776222 S776042
Jun-67 S612949 S613029 Oct-70 S780000 S780026
Jul-67 S616732 S616442 Nov-70 S783436 S783445
Aug-67 S618088 S618020 Dec-70 S786285 S786354
Sep-67 S620765 S620796 Jan-71 S789786 S789863
Oct-67 S623856 S623992 Feb-71 S789791 S789928
Nov-67 S633773 S633740 Mar-71 - -
Dec-67 S636539 S636717 Apr-71 S794694 S794763
Jan-68 S639513 S639279 May-71 S798220 S798519
Feb-68 S643522 S643538 Jun-71 S802546 S802682
Mar-68 S647473 S647430 Jul-71 S805082 S805188
Apr-68 S651667 S651556 Aug-71 S807218 S807124
May-68 S655355 S655569 Sep-71 S811211 S811235
Jun-68 S659130 S659141 Oct-71 S813802 S813870
Nov-71 S818096 S818150 Aug-75
Dec-71 S820704 S820705 Sep-75
Jan-72 S823820 S823815 Oct-75
Feb-72 S826673 S826954 Nov-75
Mar-72 S829319 S829320 Dec-75
Apr-72 S831903 S831977 Jan-76
May-72 S835592 S835649 Feb-76
Jun-72 S841116 S841110 Mar-76
Jul-72 S843408 S841907 Apr-76
Aug-72 S844384 S844390 May-76
Sep-72 S851747 S851723 Jun-76
Oct-72 S852994 S852973 Jul-76
Nov-72 S856688 S856666 Aug-76
Dec-72 S859284 S859283 Sep-76
Jan-73 S863541 S863510 Oct-76
Feb-73 S866573 S866560 Nov-76
Mar-73 S870167 S870107 Dec-76
Apr-73 S872401 S872400 Jan-77
May-73 S876358 S876400 Feb-77
Jun-73 S880704 S880700 Mar-77
Jul-73 S882341 S882335 Apr-77
Aug-73 S884409 S884406 May-77
Sep-73 S887993 S887990 Jun-77
Oct-73 S892438 S892435 Jul-77
Nov-73 S896765 S896777 Aug-77
Dec-73 S898801 S898811 Sep-77
Jan-74 S903174 S903177 Oct-77
Feb-74 S906620 S906615 Nov-77
Mar-74 S912130 S912132 Dec-77
Apr-74 S916605 S916609 Jan-78
May-74 S920619 S920610 Feb-78
Jun-74 S925946 S925941 Mar-78
Jul-74 S929496 S929483 Apr-78
Aug-74 S936065 S936055 May-78
Sep-74 S938000 S937995 Jun-78
Oct-74 S940919 S940914 Jul-78
Nov-74 S946497 S946491 Aug-78
Dec-74 S949507 S949505 Sep-78
Jan-75 S954890 S954893 Oct-78
Feb-75 S961965 S961968 Nov-78
Mar-75 S963400 S963406 Dec-78
Apr-75 S968535 S968537
May-75 S974093 S974097
Jun-75 S977028 S977033
Jul-75
Grani
Re: Fordson Industrial Engine serial Numbers
Post by Grani »
I have waited for this information for a very long time. :buddies:
Jimcdbts
Post by Jimcdbts »
I will need to try and edit it a bit as it was in the form of a table but when i posted it the borders didn`t cross over and the list is a wee bit jumbled. up .Have had this info for over 25 years as i used work for a local engineering company where we used loads of Ford engines from our local power products dealer to install in all types of industrial plant and equipment .During My time it was mostly 2720 and BSD series engines but i do have all the books still and all the design installation books for the engines. Ford Power Products were great as you could build an installation and order up any parts within ford parts division as an OEM customer.We used parts from tractors, D series and cargo trucks , R series buses and even transits we even used axles from the FW60,s all ordered through the Ford Power Products division.
Grani
Post by Grani »
Yes, a more organized information would be better to read. I am interested in all kind of information about the 590E engine and it´s history in Dagenham at that time.
Jimcdbts
Post by Jimcdbts »
In 1990 we took delivery of the last 2726T engines we could get as dagenham stopped production of 2700 range diesels for trucks and industry. Over the years we had all different models all now only as diesels. 2701E ,2701C,2711E ,2712E ,2722 , 2706E all 4 cyl, 2703E,2703C,2704C, 2704E, 2704ET,2708E,2709E ,2713E,2714E,2715E ,2723,2725,2726T, 2726TG,2726TM and 2728T all 6 cyl.Most likely all these variations may be found in the Fordson major as a conversion either as 4 or 6 cylinders.and be used in all types of Ford based tractors .A turbocharged version of the 590E was also avialable.
Grani
Post by Grani »
At my workplace, we have a sprinkler fire pump powered by a Ford 2725 that has an automatic start in a situation of both fire and blackout. It has less than 100h on the hourmeter. :cry:
Post by Dandy Dave »
Grani, Tell them it is old, obsolete, and hard to get parts for. Tell them it is time to up grade and you will be glad to haul the old unit away. :wink: Dandy Dave!
Grani
Post by Grani »
Dandy Dave wrote:Grani, Tell them it is old, obsolete, and hard to get parts for. Tell them it is time to up grade and you will be glad to haul the old unit away. :wink: Dandy Dave!
Yes I have had dreams about that, but they aren´t that stupid. :scratchhead:
Jimcdbts
Post by Jimcdbts »
fordgek
Post by fordgek »
Hello, i have County 1124 how can i found out where enginenumber is standing? By the fuelinjectionpump? And how i can found out wich type engine i have in the my County 1124. It must be a 2704/2714. But where can i found that. Greetings Jans
d.andersen
Post by d.andersen »
I wonder about something - the list describe the 510 as a
Thames trader engine , I have a 510 engine from a combine
which I then will believe is a industrial engine .
Fordson forever
county654
Post by county654 »
Hy Anderson,
your engine could be the same like one I have bought this year.
onthe last post of this thread
:arrow: http://www.fordsontractorpages.nl/phpbb ... &start=375
you find a good xplanation on the 510 prefix.
Regards Matthias
With County, you can ;-)
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
d.andersen
Well I found this some years ago,which explains the story, but still wonder why the is refered as lorry engine, when often used in combines ..etc.
http://www.dieselenginetrader.com/diese ... eadid=2173
Fordson forever
1962 model
Post by 1962 model »
Jimcdbts wrote:I will need to try and edit it a bit as it was in the form of a table but when i posted it the borders didn`t cross over and the list is a wee bit jumbled. up .Have had this info for over 25 years as i used work for a local engineering company where we used loads of Ford engines from our local power products dealer to install in all types of industrial plant and equipment .During My time it was mostly 2720 and BSD series engines but i do have all the books still and all the design installation books for the engines. Ford Power Products were great as you could build an installation and order up any parts within ford parts division as an OEM customer.We used parts from tractors, D series and cargo trucks , R series buses and even transits we even used axles from the FW60,s all ordered through the Ford Power Products division.
Thanks for all that facinating information,
Here is a bit more information for you: I have a Thames Trader engine here which cost me $50 and a 800km return trip, it carries a cast date 5 A 8 ( Jan 1965 )
This was a transition engine just before they changed to the full K series engine, it has the K series sump but still has the earlier cam, waterpump and late Super Major type injection pump arrangement.
I have struggled to find any information about the engine prefix which is 660EE 13235, as this is a transition model engine carried over into the K series truck it may be helpful fill some gaps in your records, perhaps they only made these for a couple of months, I know 1966 has the upgraded engine.
From industrail parts books of the 1965 era it appears to still be a wet liner engine in a K series, but I don't want to strip it as I want to try to use it as is in a E 27 N 6cyl tractor conversion using a E 1 A gearbox, though some work will be required as it was laying on the ground since about 1980, I have patched up an injection pump for it, and it still turns over fine.
Mike
mechman
Post by mechman »
Hi Jimcdbts
I had look at your ID tables but coudnt ID mine its up and running now but still its good to have info.
I entered a post in august under Parts swap forum,Topics Ford 4D engine with all the info I could glean from engine casting numbers ETC just wondering if you could pin it down,It was part of a welding plant.
Norm :?
Just reviving this to add a few missing details.
Lorry numbers are of three distinct types:
ET6 type, with the ET6 having the Ford V8 and the ET7 having the P6 coming beforehand, introduced March 54, Mk2 from 500E-46803
500E- 4 cyl petrol - up to Mk2 100 mm bore, Mk2 onwards 95 mm bore
502E- 4 cyl diesel - max revs 2500 rpm
Thames Traders, introduced April 57, Mk2 from approx 4 cylB-31000, 6 cylB-100000
528E- 4 cyl petrol
530E- 4 cyl diesel - max revs 2500 rpm
508E- 6 cyl petrol
510E- 6 cyl diesel - max revs 2500 rpm
and normal control Traders, introduced May 62, replaced the 500E/502E using the Ford Köln cab
622E- 4 cyl petrol
624E- 4 cyl diesel - max revs 2500 rpm
658E- 6 cyl petrol
660E- 6 cyl diesel - max revs 2500 rpm
Beware with NC Traders, as they evolved into the Ford K series powered by 2700E engines, I think the petrol one remained Major powered until it was dropped in 67.
Different fuel engines were in the same series, 4 and 6 cylinders running independently. Each type of vehicle has it's own series.
From November 61 these numbers were modified by adding a second letter denoting year as with tractors. Vehicle numbers became even more similar to tractor numbers, the code before the year letter indicating the payload capacity and a number series that changed every year. I think 4 and 6 cylinders ran independently but don't know for sure. model codes are more varied, these are the ones Ford chose thinking they would be the commonest (as happened with Major's having most common parts with E1ADKN part numbers until the Power Major when E1ADDN took over).
Industrial numbers:
S prefix for 589E, 590E, 591E and 592E from April 57 onwards (Mk2 type).
589E- 6 cyl petrol
590E- 6 cyl diesel - max revs 2250 rpm
591E- 4 cyl petrol
592E- 4 cyl diesel - max revs 2250 rpm
All were in the same series, from March 65 the 2700E engines were also made in the same series, April 70-74 made by Ebro but still with Ford markings and numbers. Parts in these engines were predominately lorry based but not always.
R prefix for 953E, 954E, 955E, 955E, 562E and 563E to April 57 (Mk1 type). Not too sure about this but this is what seems to have cropped up. If anyone can confirm this it will open up the Mk1 industrial history.
Tractor based
953E- 4 cyl petrol zero octane
954E- 4 cyl diesel - max revs 1600 rpm
955E- 4 cyl petrol - 95 mm bore
956E- 4 cyl TVO
Lorry based
562E- 4 cyl diesel - max revs 2500 rpm
563E- 4 cyl petrol - 100 mm bore
Put these in inverse order as I'm not yet very clear on Mk1 details. AS far as I know they were all in the same series
Any number that doesn't conform to tractor or the above types might well be an Ebro number, confirmed if the engine is made after 1958 and has a number under injector no.4 that doesn't conform to Ford ones either, Ebro made engines until 1980. Mk1 numbers are not yet very clear.
This is still incomplete, there's still a lot of missing information. I suspect fairly few Major engines were sold after the 2700E engines appeared so we'll never probably know the total production, Ebro is still not very well documented either.
1962 model
Thanks for that,
Actually, I can add a bit more too, Petrol Power Major engines did appear after the official tractor cut off point for those engines, in industrial machines.
Our late petrol Power Major engine was fitted to a Cranville crane in eastern side of Australia through Power Major skid units being supplied later than tractor production. Our 4cyl engines for some reason on this side of Australia carried reduced engine prefixes than published.
Our Power Major tractors on this side of the country were assembled in Perth Western Australia 4000kms away from where our Cranville crane was constructed. My son and I have several Power Majors Tractors we plan to get going and are about to collect another one in the next few weeks.
Sounds like your quite busy. As far as I know petrol tractors were available until the very end, but they were rare. The only engine that was discontinued early on was the TVO in March 57 (both tractors and industrials). Not sure I understand what you mean with reduced prefixes, the only cases I'm aware of are a few November 61 tractors that had a Z instead of the 08A. Good luck with your latest find!
1962 model
Our tractors on this side at least do not have the 08 in front of the engine number and just start with a C then the number, perhaps the individual assembly of export tractors were meant to put the 08 in front to signify assembled in Australia, however as our tractors did not usually leave the country they may have thought that that step of adding the 08 at the front was unnecessary. No one here in Australia has yet explained the reason to me.posting.php?mode=reply&f=2&t=5626&sid=7 ... c04ff4851f#
One of our tractors actually has the C stamped backwards.
This added prefix reminds me a bit of my HZ Statesman Holden car which on assembly had engines taken from a rack of engines and only when fitted to a Statesman they added an 11 at the front of the pre-existing engine number to signify it was a Statesman only engine, in reality there was little difference if anything. Mike.
Very strange, wonder if Dexta's are the same as otherwise there's no way to distinguish between the two after November 61. The 08 was for Dagenham to use a computer on spares and stuff of that sort. The reversed C is probably just a mistake from loading up the stamper one day (I'm sure there will be more similar events). All Major's and Dexta's were in a world wide series (as listed many times in manuals and so on) except anything made by Ebro (but not necessarily sold by them).
1962 model
Yes the numbers seem to be strange alright, engine numbers published by my Australian tractor club make no sense to me at all.
My 1958 Dexta is 1419755 and my local club just states 144 for 1958, that is more like the engine size, those numbers are round about ( but not exactly consistent with the Major numbers for 1958, then there is the issue of the engine cast dates, it seems Perkins followed a different format for dates, that engine is cast J228 July 22nd 1958, where if Ford cast them they would have put J 22 B to conform to their block cast dates.
My red wheel Super Dexta project tractor is 1613726 cast P 6 2, Ford would have put P 6 H if it was a Major, also the engine number does not conform to published material which would have had it being 09B7*******
The published material has it that the Dexta numbers changed to the new system in November 1961 09A ***** and ran through to 1964 being 09D******
Here is proof in a 1962 engine that this did not occur for some reason that I cannot explain!
Maybe this needs to be under a Dexta topic, feel free to copy it across.
I don't have a white ( grey wheel ) NP Super Dexta for a comparison, Mike.
Dexta's had separate engine numbers, running from 1400000 to 1553322 and Super Dexta's from 1600000 to 1664496, this is different from the serial number which was 957E prefixed until November 61 (Petrol models were 959E) and was stamped on the bell housing flange next to the timing inspection cover.
Dexta's and Major's never ran in the same series.
As for casting codes only the engine ones are odd, the rest are like Major's, the engine codes are in a separate Dexta thread, and they're on the block and head as far as I know (the head one is under the rocker cover, visible through the oil filler).
Just found some new information. We now have some vehicle numbers as used from November 61. Format is L weight in tenths of a ton Year letter- vehicle number- month letter
Domestic Export
end month 4cyl D 6cyl D 4cyl P 6cyl P 4cyl D 6cyl D 4cyl P 6cyl P
N61 296352 292298 296350 292290 296353 292300 296355 292292
P61 296686 293160 296681 293151 296690 293165 296687 293155
A62 852405 831200 852392 831101 852382 831197 852395 831139
B62 852780 832055 852765 831701 852753 832054 852777 832052
C62 853297 833145 853282 833098 853279 833156 - 833155
D62 853840 833887 853732 833315 853842 833886 853489 833861
F62 854500 834845 854507 834842 854502 834847 853864 834590
H62 870292 846349 870084 836789 870292 846349 870258 846167
J62 855961 837138 855775 837084 870339 846678 870344 846601
K62 856378 837206 856361 837654 870520 847011 870524 846859
L62 856818 838379 856685 838199 870726 847251 870710 847196
M62 856884 838865 857052 838599 870877 847780 870866 847492
N62 857550 839373 857496 838873 871113 848244 871131 848287
P62 857710 839865 857600 839818 871245 848846 871258 848358
A63 852398 830781 852399 830430 871302 844172 871362 844155
B63 852674 831211 852577 831246 869097 844562 869067 844402
C63 852692 831646 852792 831545 869269 844957 869270 844936
D63 853119 832173 853092 832136 869479 845414 869422 845350
F63 853735 833091 853670 832480 869708 846141 869715 845803
H63 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
J63 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
K63 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
L63 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
M63 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
N63 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
P63 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
A64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
B64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
C64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
D64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
F64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
H64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
J64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
K64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
L64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
M64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
N64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
P64 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
A65 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
B65 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
C65 ?????? ?????? ?????? ?????? ?????? ?????? ?????? ??????
These were on the plate fitted to the mudguard under the bonnet where previously the engine number was, it also carries the model code.
Also some details on the earlier numbers:
Jimcdbts wrote:
Sun Dec 15, 2013 11:24 pm
Jan-57 - - Apr-60 17522 46167
Feb-57 - - May-60 17963 48135
Mar-57 - - Jun-60 18646 49708
Apr-57 0001 0001 Jul-60 19178 51667
Jun-57 ????? ????? Sep-60 19962 54650
May-58 ????? ????? Aug-61 26050 76353
Oct-59 14249 34730
Nov-59 14774 36139
Dec-59 15210 38002
Jan-60 15768 39995
Feb-60 16975 42036
Mar-60 17250 43892
August 59 doesn't seem to be in the list, don't know why.
Hoping to get more soon, also 500E/502E numbers and industrials before March 59.
