http://www.youtube.com/watch?v=SCg2rlcnYZ8
To tell you, Im surprised that the tractor's engine didn't even labor at all when it happened...
Also, I think the bad thing about no-till method is that the soil will be compacted as time passes. In fact, we left our field uncultivated for several months only and when it is the time to plant onions, we discovered that the soil was so hard that the disc harrow was just "rolling" on the ground, even on full depth! (Here in our place, farmers "plough" using offset disc harrows, which as far as I know, wasn't really a plough, instead they're harrowing, isn't it?)BearCreek Majors wrote:I was watching the “Farm Report” on TV several months ago and they were saying that no till just hasn’t taken over the way it was predicted to years ago. Many no till farmers are still plowing most acreage every couple of years. The farms that grow vegetables around here never stopped plowing yearly, as Pavel points out largely for weed control, most of the vegies are planted by means of transplanting the young plants from seed beds and they want the fields to be good and loose for the roots to take hold and as weed free as possible.
Used plows still bring good money in this area.
Pat
Good thing that your e27n crawler could pull a 4 furrow disc plow. Here in our area, the four furrow disc plow is only reserved for the more powerful tractors. One of the farmers here uses a 4 furrow disc plow, but he owns TWO FORD 7000sbrockwood wrote:For those who havent seen a shearer royal in action got a heaver 6 disc majestic for this year was ploughing scrub at the bottom of the paddock b http://www.youtube.com/watch?v=LQgI6y50-IY
