I'm hoping to get my Power Major out and over the winter I know condensation builds up inside making the oil diluted. I wanted to ask since the water should be settled to the bottom can I slightly loosen the drain plugs and let some of the water out?
Condensation
Condensation
Gman: 1959 Power Major
Re: Condensation
Dear GMan
You can, but prepare for cold water and oil down your arm, as it can come out with a heck of a rush and it can be very difficult getting the plug back in against the flow. Have plenty of containers around if the inevitable happens!
Tim E
Tim E
Re: Condensation
HiGman wrote:I'm hoping to get my Power Major out and over the winter I know condensation builds up inside making the oil diluted. I wanted to ask since the water should be settled to the bottom can I slightly loosen the drain plugs and let some of the water out?
There is a very fine line of letting the water out
Re: Condensation
Thanks all. I've done this when changing the engine oil and never no water. Thought it may also work with the trans and backend since she has sit for so long this winter.
My oil is not that old, not wanting to do a compete change at this time.
Thanks again.
Thanks again.
