fuel tank feed options
botchit
Post by botchit »
I recently noticed fuel leaking from the pumping button and fuel feed to the inlet manifold. I have ordered a replacement but this doesn't have the manifold feed. This is obviously to aid starting but doesn't appear on the super dexta. Is it vital and where would I get a replacement part? Agriline did stock this item as a special but it was very expensive for what it is. Any advice or help much appreciated!
cheers
Botchit
Re: fuel tank feed options
Post by Bensdexta »
botchit wrote:Hi
If your engine, injection pump and injectors are in good condition, the primer fuel feed is not essential except in sub-zero weather. Heat alone should usually be enough. If you have access to a machine shop, you could always rebuild your old primer after Stefan, using stihl chainsaw bits, as I have. Not that difficult and works well.
See here:
http://www.fordsontractorpages.nl/phpbb ... f=3&t=2079
