I have a 1964 Fordson Super Dexta that I would like to install a swinging drawbar. Can anyone tell me if the swinging drawbar that fits a Ford 8N or Ferguson TO 20 will fit my Super Dexta?
This is what I am looking at:
http://www.amazon.com/Swinging-Drawbar- ... B0076Q5Y2U
Or:
http://www.yesterdaystractors.com/Ford- ... 9A34R.html
I am in the United States, so Super Dexta drawbars aren't as easy to find as older Ford drawbars.
Thanks, Terry
									swinging drawbar interchange
Re: swinging drawbar interchange
hi idont know if they can be made to fit the dexta
drawbar dexta is roughly 42 inches long
so that one is shorter for a start, the part which anchor,s
the drawbar may not line up hole wise either, there are four,
also the swinging part of the hitch has four holes to
line up, the thickness is ok at 1 inch same as dexta ,just some things to consider before you spend your hard earned.
