Belt & Lower Radiator Hose
				DntBrnDPig
Can anyone take a picture of the clearance between the belt and the lower radiator hose?  It almost looks like on mine that the belt has notched out the hose for clearance.  Don't think i have any leaks but it just seems incredibly tight.
						Re: Belt & Lower Radiator Hose
Well known problem.
Some hoses give more clearance than others. Try twisting the hose to give a bit more clearance.
With mine I ended up cutting a 2" piece out of a tin can and tie-wrapping it around the hose to protect it from the belt. Seems to have worked.
				DntBrnDPig
Thanks!  Makes me feel better
