I was bushing hogging today and started hearing some loud metal popping sounds coming from my front right wheel.  I'm going to jack it up in the morning and get a closer look.  Has anyone replaced wheel bearings in front?  If so - is this the symptoms you encountered as well?
-Pig
						Metal popping sound - front wheel
				DntBrnDPig
Re: Metal popping sound - front wheel
Either wheel bearing or loose wheel. Easy enough done. An hour tops.
That is what I would suspect too. Now a question, has anyone found that the seal supplied in the bearing kits does not fit on the stub axle? Or has Dotty got a different stub axle.
				DntBrnDPig
Got the tractor jacked up and hit it a couple times with the air impact driver and tested her out.. no pops.  The wheel must have been lose.  Thanks for mentioning that!
