Fuel Pump Gaskets
Fuel Pump Gaskets
Whilst in the process of taking the hydraulics apart, I have also taken off the fuel pump and injectors and will send them off to Peter Strong for testing / repair whilst we are off the road. Does anyone know where I can get gaskets for the pump flange, timing front and side covers? It's an earlier pneumatic governor pump. Agriline don't appear to list them, although they may be part of an engine kit, I will have to phone them tomorrow.
						Re: Fuel Pump Gaskets
Contacted Agriline and the fuel pump fitting gaskets do come in the bottom end gasket set. All the surfaces have been cleaned up, so when I get the pump back refitting should be no problem.
