fast idle
Re: fast idle
Adjustment is on the intake manifold, two screws, one fast the other slow, they set the position of the butterfly in the manifold.
If you have a Minimec pump the adjustment is on the throttle lever on the pump. Again two screws.
Re: fast idle
thanks Brian, I thought so. The large screws wired and locknuts on them I assume
