Source for parts?
Source for parts?
Does anyone have a source for Lucas starter parts that are reasonable for a dexta?
									Thomas Miller
						Re: Source for Lucas parts?
How about these guys?tomsdexta wrote:Does anyone have a source for Lucas starter parts that are reasonable for a dexta?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0019661437
or
http://www.woodauto.com
just type the Lucas Starter Code (26072) into the search form and you will see all the available parts. Try to order your parts there or through your local Auto Electrican.
Not the right side of the pond but OK as a starter!!
 Ben
Hi,tomsdexta wrote:The starter code you listed, is it the number that is stamped on the starter housing itself? If so the number doesn't match. The number i took off my starter is 26143B. Was there a different starter at some point?
I don't know. If you put the numbers into the Woodauto site I listed you can have a look and maybe compare component numbers.
Suggest you email the guy I listed ^, or this guy
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0296627094
or Woodauto, or your local local auto electrician.
See also
http://www.fordsontractorpages.nl/ubb/F ... 01149.html
All the best,
Ben
Starter Parts
Tom,
If you're still stuck, sounds like Stefan may be able to help:
http://www.fordsontractorpages.nl/phpbb ... ight=#1986
All the best,
Ben
All the best,
Ben
