Super dexta oil
Super dexta oil
Hi, we were finally able to start my super dexta by pulling it off,although my hydraulic lift would not come up. I still have some issues to fix. Anyway I was going to change the oil in the rear end/hydraulic.Im I correct in reading that you need to put Sae 30hd in everything? Thanks for any help.
Re: Super dexta oil
HD 20/30 is best or any Multigrade oil that does not have additives for oil cooled brakes in it. I run Morrises 20/50 in all mine but it depends on your climate.
Re: Super dexta oil
So you run 20/50 in your engine, tran and rear end? Temps here are upper 90's in the summer and upper 30' in the winter.
Re: Super dexta oil
Yes, and with those sort of temperatures you will be fine. 30HD would be fine too if you can get it.
