1964 Super Dexta brakes
Dexta blue
Before I dismantle the brake drums on my super dexta , what might the main reason be my brake pedal sticks in the down position when I brake ?
Re: 1964 Super Dexta brakes
Seized pins in the linkage, cross shaft to brakes tight, weak springs in the brakes. (See other post on brakes).
Dexta blue
Thanks Brian , A good checklist.Brian wrote:Seized pins in the linkage, cross shaft to brakes tight, weak springs in the brakes. (See other post on brakes).
