Have any of you done anything with this feature?
I can imagine a dump trailer, after chaining down the lift arms.
Any calls on the pressure and flow rate (both ways)?
TIA
Cal
ETA E27n
Hydraulic pressure tap on single lever lift?
Re: Hydraulic pressure tap on single lever lift?
Hi Cal
Can't help you with pressure and flow but somebody added a double acting spool on my p6, what they used it for I have no idea either
. It takes pressure from the tip port and returns it to the plug at the back. I would think to do anything sensible with a tipping trailer you would be needing an extra tank, like they had fitted for a loader
. I think there would be a shortage of oil in that housing ,it's not that big of a capacity from what I can see
http://www.fordsontractorpages.nl/phpbb ... 272#p32272
http://www.fordsontractorpages.nl/phpbb ... 309#p26309 heres a couple of old posts . currantly runing a mm cub dozer single acting on the halftrack 3 imp gallons a min at 1700
