Hi all.
Can anyone please decode the Australian fordson serial numbers as stamped on the id plate. I figure the date is obvious but unsure how to understand the rest. My power major plate is as follows.
 5 B M.1.60  2767  A529
It has a number stamped on below the fuel lift pump on the chassis rail which is V007004P
Below number 1 injector on the horizontal surface is stamped V007003P.
The engine number is stamped above starter motor and is 1524778 indicating a built date of September 1959.
Any information will be appreciated.
Thanks Ben
						Australian serial numbers
Re: Australian serial numbers
The BM stands for Broad Meadow Ford plant where the tractor was  "Australianised"
The numbers are Australian numbers and I do not have any information on them but your dating is about right. Built in England in 1959 September, then a couple of months shipping to Broad Meadow, dated 1960 for Australian records.
Barry M might have more information.
The numbers V007004P and V007003P have been stamped on the tractor by the Victorian Police.  The tractor has been taken to a Police Station for a Registration and Victoria Police would never accept the fact that there was no such thing as a Chassis Number on the Fordson, so gave it one.  They obviously couldn't find the Engine Number and seeing a blank space on the Block have give it a new number.
									BarryM
