I've just ordered a new plough lamp, and was wondering on which side wing it should be mounted and where is the right spot.
Do I have to put extra wiring?
the lamp i bought is: http://www.ebay.co.uk/itm/BLUE-PLOUGH-L ... 0033.m2042
thanks!
plough lamp
plough lamp
- Contact:
Re: plough lamp
Mine is on the right side.
Re: plough lamp
If you have a reversible plough Mathias, you may find you need one on both wings
They generally seem to be sited about 1/3rd of the way forward from the rear of the wing, as high and as outboard as you can fix them
