Unload valve
woodcutter
Unload valve
Post by woodcutter »
I’ve just took the lid off my super major and valve was stuck so now it’s removed the oring is no good what’s my best option can I just put it back in with out oring will it all work ok? or try to find an oring
Re: Unload valve
somewhere on the forum Brian advised it's better to leave of the o-ring. I've done this also and the hydraulics did work without it.
woodcutter
Re: Unload valve
Ok thanks valve still seems sticky, when pushed right in but smooth until it gets up to the end
