Petrol dexta
Stuss
Petrol dexta
Post by Stuss »
Hi everyone. A few questions regarding my petrol dexta thought was going to be an easy restore .
Fitted a Agriline headgasket and ended up with water in oil, removed head to find the gasket stud holes bigger than the old gasket . We can push gasket hard one way and it covers the water jacket holes but pulled back gasket on edge of the w/j hole , gasket is 2mm movement on the studs. Might have to get a gasket made , anyone had this problem ?
The 2 stage clutch is it a Dexta or a ferguson or are they the same ?
What have other fellows done with the ring gear, can we get another or press this one off and rotate it ?
I realise it’s the standard industrial motor as fitted into the 701 hay balers ,
Any would be appreciated
Stuss
Re: Petrol dexta
Post by Stuss »
No one can help ? Okay. Getting ring gear made if anyone’s interested
Re: Petrol dexta
Stuss wrote:No one can help ? Okay. Getting ring gear made if anyone’s interested
Stuss, Agriline sells these ring gears as replacement. That will be cheaper than to have one made.
Stuss
Re: Petrol dexta
Post by Stuss »
Petrol Dexta is a diferent ringear 155 teeth , Brian Dye done a lot of reaserch into this and come up blank , I’m looking at getting one made
skipdow
Re: Petrol dexta
Post by skipdow »
I reused my head gasket since it was copper. You can anneal it by heating it up with a propane torch and dropping it on a colder sheet of steel. basically it deforms the gasket so it can crush again when torqued. Its common practice on old high performance engines so they can do engine work often without needing new gaskets all the time. Did that to mine last year and so far no oil in water and no water in oil and has great compression. I did however put a very thin coat of high temp silicone on the gasket around the water ports.
